View Poll Results: What is a safe RPM for a stock bottom end with aftermarket springs?
6300 RPMs
38
8.46%
6400 RPMs
25
5.57%
6500 RPMs
89
19.82%
6600 RPMs
44
9.80%
6700 RPMs
45
10.02%
6800 RPMs
118
26.28%
6900 RPMs
29
6.46%
7000+ RPMs
61
13.59%
Voters: 449. You may not vote on this poll
Safe RPMs on a stock bottom end with springs
Old 07-24-2006, 02:56 PM
11Second Club
Gauge's Avatar
Default Safe RPMs on a stock bottom end with springs
I seem to be getting largely varying answers to this question, so I thought a poll would be prudent. If you've got a set of aftermarket springs (Crane Cams double springs, in my case) but a stock bottom end, what is a safe RPM to rev the car up to?
Old 07-24-2006, 03:00 PM
allngn_c5's Avatar
I am using the comp 921's and currently my rev limiter is set at 6800 rpms. When my next stuff goes on, and my new 921's go in I am having the rev limiter raised to 7100 rpms. LG Motorsports claims that isn't even the max at what these valve springs can handle. Good luck with your setup. Don't miss any shifts that all I can say.
Old 07-24-2006, 03:01 PM
sickss228's Avatar
What year are you talking about I"m assuming 2002? I'm pretty sure they changed the rod bolts in the 2001's and they can handle around 6800 rpm.
Old 07-24-2006, 03:25 PM
lt1formula2000's Avatar
I voted 7,000. I have a stock bottom end pistons rods crank but I do have ARP rod bolts. I 'm not sure if this is enough consider it no longer a stock bottom end. If the rod's bolts where stock and I had a 98-00 I would just hope my luck held outand go to 6800, and a 01-02 I would go to 6800 and feel a little safer, cause hey other people do it all the time.
Old 07-24-2006, 03:33 PM
Super Hulk Smash
JakeFusion's Avatar
Good springs, good lifters, and ARP rod bolts = 7200-7400 RPM
Old 07-24-2006, 03:49 PM
11Second Club
Gauge's Avatar
Stock bottom end = stock rod bolts.
Old 07-24-2006, 04:24 PM
Viper's Avatar
Stock bottom end = stock rod bolts = 6500rpm on the older rod bolts. Even with the new ones I wouldn't go past 6800.
Old 07-24-2006, 06:35 PM
john59's Avatar
The redline on a stock Z06 is 6500 i believe, 02 and up, so is it safe to say that you could go to 6800 without problems up the road on an LS1 that is newer than 2002? The rod bolts like has been said earlier were changed in 2002.
John
Old 07-24-2006, 07:00 PM
67Firebird455's Avatar
What about the oil pump in these engines? What really is the difference between the LS1/LS6 oil pumps? I think that is something to take into consideration.
Old 07-24-2006, 07:02 PM
gillbot's Avatar
I spin mine to 6800 and nothing has broken yet. ::knocks on wood!::
Old 07-24-2006, 07:09 PM
brady346's Avatar
6500 on stock bottom end and valvetrain.
Old 07-24-2006, 08:12 PM
redtail2426's Avatar
the rev limiter on the 02 and up Z06 is 6600.
Old 07-24-2006, 08:22 PM
mikep182's Avatar
I wouldn't go over 6500 on 98-00 rod bolts. 01-02 and I'd feel alright goin' to 6800.
Old 07-24-2006, 08:25 PM
trans_am_31's Avatar
I would go between 6,500-6,800 safely with the aftermarket springs you have. Good luck.
Old 07-25-2006, 08:32 AM
GuitsBoy's Avatar
yeah, 02+ z06 is 6600 rpm. I believe mid year 2000 and later lsx engines got the updated rod bolts. I spin my 2002 to 6800 from time to time. I have a ton of oil pressure still, even with 105K miles. Im not too worried.
Old 07-25-2006, 10:40 AM
300bhp/ton's Avatar
So whats the weak point on the bottom end? What usually lets go?
Old 07-25-2006, 11:12 AM
Josh@KY-Turbo's Avatar
The stock rods bolts are the weak point in the bottom end. RPM is the killer in these stock bottom end setups. I figure I will spin the crap out of mine unitl it lets go. Then break out the emergency credit card and build a new motor.
Old 07-25-2006, 08:08 PM
i want to know who voted 7000+ rpm on the poll
Old 07-25-2006, 09:12 PM
BadAzz96Z28's Avatar
02 TA with stock bottom-end, 25k miles, comp 918's and I spin it to 7000 everytime I drive it. No issues at all.
Old 07-25-2006, 09:50 PM
GuitsBoy's Avatar
Ive heard of lots of people spinning 7K+ without trouble on an 01+ stock bottom end... I wouldnt trust going that high with my daily driver personally though...
Quick Reply: Safe RPMs on a stock bottom end with springs
