4L60e behind a turbo motor???
Old 07-26-2006, 09:41 AM
80superbu's Avatar
Default 4L60e behind a turbo motor???
Is anyone running a 4L60e behind their turbo car?
Even though I'm gonna be pushing sort of big HP numbers (650rw) I'm not building a drag car anymore. I'm going for the pro-touring effect with my 67 Chevelle. I almost want to go with a 5 or 6 speed manual trans but the cost is a big factor. I have a good 4L60 that was originally behind the stock LS1 I have. Would this hold up if I did a rebuild and upgraded a few parts?
It may occasionally see some good blasts but for sure not all the time. Mainly gonna be a driver for car shows, cruises and family outings
thanks
Old 07-26-2006, 11:50 AM
cablebandit's Avatar
you'd be better off with a 80e and a shift kit
Old 07-26-2006, 12:09 PM
80superbu's Avatar
Yeah, but I don't happen to have an 80
I have a nice built TH400 but I want some sort of overdrive '
Who built yours and what was the damage? You can PM me if ya like
Old 07-26-2006, 12:18 PM
lok thru the fs adds....someone had one fore like 1000 dollars here in Marietta...already had a shift kit in it.
Old 07-26-2006, 12:36 PM
67Firebird455's Avatar
My bud has a 60E behind his turbo 347 and has had it in the shop for rebuilds what... like 3 times now in the past 6 months?! LOL DO NOT boost going into OD!
Old 07-26-2006, 12:47 PM
King James's Avatar
Do a search over at CF and see how many of those boosted guys are successfully running RPM 4L60E's. Rodney at RPM has had great success with his 4L60E's.
If your not going to be beating on it all the time I bet the right builder can get the 60E to live in your car.
Old 07-26-2006, 12:50 PM
Agreed, it all depends on if you beat on it non-stop, especially in the scortching heat of california (lately)!
Old 07-26-2006, 06:58 PM
Sixspeed02TA's Avatar
Give Dave over at Rock-On Transmissions a call. He's doing my setup (700 - 800). He said he's comfortable with the 4L60Es up to 700. ~$1800
Old 07-26-2006, 07:37 PM
JMBLOWNWS6's Avatar
Ya good luck finding a 80 for sale. I used alot of my connections to get a core for under $700. The problem is that there is the $750 core charge on top of the 1500+ you spend on the tranny alone. Lucky I found one with a manual valve body installed and I will manually lock it up with a push button mounted to my console and the B&M shifter. Good luck.
MiaSSmaro98's Avatar
damn 1800 bucks for almost 700 hp sounds good
Old 07-26-2006, 07:50 PM
80superbu's Avatar
I can get an 80 out the doow w/no core for $1800 or 1300 w/core. I may play with this 4L60 I have for a while and see what happens...bada-boom
Old 07-26-2006, 08:14 PM
LS1NOVA's Avatar
Im in the same boat. Looking to make 500-600 rwhp and already have a 60E. I am going to upgrade the 3-4 clutches, beast reaction shell and run it for a while until it blows. In the meantime, save some coin for a 80E and convertor. You can find used 80E's on car-part.com for around 700 with low mileage. Then all you would have to do is put in a shift kit and go.
Old 07-26-2006, 08:55 PM
Lafngas98Z's Avatar
You can spend the money on a built 4l60e with a warranty and spend your life changing out trannies every 2 months or do it right the first time and buy an 80. Its a lot less hassle going with the 80!
Old 07-26-2006, 09:02 PM
ABeasst's Avatar
what do 4l80s come in again? 2500HD trucks?
Old 07-26-2006, 09:26 PM
LS1NOVA's Avatar
2500 and 3500 2wd trucks-99 and up with a 6.0
Also 2500 new body vans with the 6.0.
You can also make the 98 and older work but I dont think its a direct bolt up.
Old 07-26-2006, 09:29 PM
Got Me SOM's Avatar
My friend Dave aka Caveman on here has a Century built tranny 4l60e and that sucker has lasted and he was running that car every week. his blower engine was making 650 rear wheel and it was holding up just fine.
Old 07-27-2006, 01:03 AM
Candlebandit had a Rock-On 4L60E...... then his converter turned loose and took out the tranny with it (on his 130th 10.XX pass down the track). God only knows how many street miles he had on it. Honestly, I think you would be fine with a nicely built 4L60E.
Old 07-27-2006, 10:45 AM
Zombie's Avatar
Why not use the th400 and some nice 2.7x gears?
Old 07-27-2006, 10:53 AM
kp
kp's Avatar
Really, since its just a driver and you already have the trans (hard to beat a TH400 for cost vs horsepower handling) why not just do a tall gear. It wont run that bad either if you have the right converter..
Old 07-27-2006, 11:57 AM
80superbu's Avatar
I could I guess since I have a sweet TH400 already. My rear is a 12 bolt w/4.10 posi right now. It would be easier to swap gears and carrier. 3.08 is the lowest I can go in the 12 bolt. RPM's at 65 would be 2450 w/28" tire and 2300 w/30" tire
Quick Reply: 4L60e behind a turbo motor???
