does your alternator slip?
Old 07-26-2006, 12:04 PM
cablebandit's Avatar
Default does your alternator slip?
While out tuning, i noticed my voltage plummits when i hammer the car. I am thinking the alternator must be slipping. What would help if thats the case?
With the increased revs, i wouldnt expect it to fall like that unless its slipping
Old 07-26-2006, 12:36 PM
y2khawk's Avatar
My truck does it Everything dims initially (lights and such), volt meter drops to 9 or 10 volts, and then it climbs back up to normal. Only on a flat stab to WOT though. And usually when it has to make a down shift.
I'm figuring it's the rapid accel from the downshift, and the crusty 75k mile belt that still in there.
Try a new belt maybe?
Old 07-26-2006, 12:43 PM
Coal Mining Director
onfire's Avatar
I run a NAPA belt....no problems.
How's the tuning coming? Was the rpm vs pe off a lot?
your right...its the sudden stab while cruising. Makes it harder to tune with the voltage affecting the fuel pumps
Old 07-26-2006, 01:57 PM
just went and got a new gatorback belt...ill report the outcome
Old 07-26-2006, 09:03 PM
kp
kp's Avatar
I have had a couple cars do that with a bad alternator also, they would just shut off at WOT and could never figure out why. Put a rebuilt alternator on and it was fine, same belt and pulley, not sure what crapped out in them.
Old 07-26-2006, 09:13 PM
TS6
TS6's Avatar
I've had 2 do it as well, on the same car no less.
Quick Reply: does your alternator slip?
