LS1 cam in LS2
Old 07-26-2006, 01:16 PM
TheCarKid's Avatar
Default LS1 cam in LS2
Is is possible to put the cam from an LS1 into an LS2?
Old 07-26-2006, 01:19 PM
viewsonic's Avatar
yes.... but why?
Old 07-26-2006, 01:21 PM
TheCarKid's Avatar
Thinkin of getttin a 6.0L iron block and wanna know if I can put my TReX in there.
Old 07-26-2006, 01:28 PM
ninobrn99's Avatar
ls2s are iron, but yes, they are 6.0 liter blocks. As for an iron block, yes you can use the cam. I thought the ls2 cams have something on them that ls1s dont..
Old 07-26-2006, 01:54 PM
sonicbaloo's Avatar
You can put a LS1 cam in a LS2 block. You might have to use a LS2 cam sprocket and the LS2 font cover to get the timing right if there is no place for the cam position sensor on the back of the LS2 blocks.
Chad
Old 07-26-2006, 01:56 PM
ninobrn99's Avatar
Thanks Chad! Thats what I was thinking of..the cam sprocket.
Old 07-27-2006, 01:03 PM
radkon's Avatar
The LS2 is an iron block? First I've heard of that!
Old 07-27-2006, 01:04 PM
ninobrn99's Avatar
****! i meant aluminum...sorry...that was my bad
Old 07-27-2006, 01:27 PM
radkon's Avatar
No worries, wasn't trying to be a jerk.
Old 07-27-2006, 01:29 PM
ninobrn99's Avatar
you werent. Im just glad you caught it. Id hate to have given out the wrong info
Old 07-27-2006, 10:07 PM
GOaT Cheese's Avatar
The LS1 cam sensor is at the rear of the block, the LS2 cam sensor is at the front. Sounds like a problem to me.
Old 07-27-2006, 10:13 PM
As Chad said, you would have to use the LS2 cam sprocket, in order for the CMP to work, maybe it's not such a problem after all.
