G5XX AND MS3 cam
Old 07-27-2006, 08:43 AM
c5_ls1_6spd's Avatar
Default G5XX AND MS3 cam
How does the LG G5XX cam compare to the TSP MS3 cam??
Old 07-27-2006, 09:08 AM
SUTTERERMAN85's Avatar
which g5xX? my G5X1 will make more low end and be better everyday on the street but will be shy power up top. G5X3 and X4 will be closer
Old 07-27-2006, 10:48 AM
PREDATOR-Z's Avatar
It is XX time bigger (LOL)
Old 07-27-2006, 11:26 AM
HOSS's Avatar
There is a thread about it the the dyno section. The LG cam is pretty large, I don't know the specs, but its the largest cam they LG makes. They dyno I saw makes more power, and more tq than most of the MS3's.
Old 07-27-2006, 11:56 AM
how much more...?
All i know is that the G5XX cam will make power to about 7800rpms.....
Old 07-27-2006, 12:04 PM
Louis's Avatar
It made 530/470 with AFR 205s on a 346 2 years ago, it isnt a cam I allow to be mail ordered, and install from us only.
http://www.lgmracing.com/lg140.wmv is a video
I installed it in Magnus' car back last fall, went 9.9x @133 If I recall. Oil starvation from a wheel stand ended that engines life so the real potential of that combo in a good negative DA has never been found.
Louis
Old 07-27-2006, 12:49 PM
wow i feel like an idiot. how long has the G5XX been out?
Old 07-27-2006, 12:53 PM
HottLS1Z's Avatar
Ha I was looking at the LG cam before I got the MS3 but I wasnt about to put a cam in my car not knowing the numbers on the cam.
Old 07-27-2006, 01:56 PM
Louis's Avatar
Almost 3 years now.
Old 07-27-2006, 02:41 PM
what LSA is the G5XX on??? how is this cam's characteristics in a 346ci??
Old 07-27-2006, 02:42 PM
sorry i guess i have been in the dark...
Old 07-27-2006, 03:39 PM
bobby1's Avatar
like bobby at lg told me its not a street cam its strictly a race cam but i will tell you this i drive mine everyday.
Old 07-27-2006, 04:22 PM
It has to be alot bigger than the T-rex becuase it requires fly cutting, and it's probably the same size or larger than the Texas giant. But is the LSA a 110? 111? 112? 113? 114?
Old 07-27-2006, 04:37 PM
bobby1's Avatar
i believe the texas giant is a stroker grind
Old 07-27-2006, 06:48 PM
SVT THIS's Avatar
It doesn't have to be a lot bigger than the Trex to flycut. The TRex is cutting it pretty close as it is. As for not installing a cam because you don't know its specs...
I think that makes sense if it is from an unreputable shop. But look at LG Motorsports. Have you seen a bad product by them? Nope. They make quality pieces that produce great numbers consitently.
I think your choice should be based on your goals for the car. If you want to drive your car everyday without possible surging issues, bucking issues, and super sky high powerband (will you spin 346 to 7800rpms without rod bolts???) then I would go with the MS3. The G5XX would be a great weekend warrior on a built 346 with the proper rear end, stall, gears, suspension and valvetrain mods along with a close enough drive to Lou's shop to get it tuned and retuned and retweaked as needed.
Old 07-27-2006, 06:59 PM
s346k's Avatar
ha. even with rod bolts, odds are you'd frag a rod bearing as the factory wet sump oiling will give up its ghost ~7,500.
this g5xx cam has my attention. appears to have a curve very similar to the x3/4, but makes more hp. i saw the numbers in the dyno section...awesome results with just 90/90. it's a shame i'm poor, i'll just do my custom grind with as cast 243s and be happy.
Old 07-27-2006, 07:19 PM
jay_99z's Avatar
What are the specs on the G5XX?
Old 07-27-2006, 07:49 PM
HeapaShifter's Avatar
The G5XX specs are super-secret. Even more so than the G5X4. I believe LGM will tell if you buy it first. These cams do put out some of the best dyno #'s and track times, so I am a fan.
Quick Reply: G5XX AND MS3 cam
