where to get a zo6 maf for a good price and will it fit on slp air lid
As title says looking for zo6 maf fairly cheap gm is more expensive than getting a slp or granitelli/zo6 from speed inc. Also what to do to get it to fit on slp bellows and air lid
thanks
thanks
you would just loosen the clamps and slip it on. Also unless your pushing 500 + HP its a pretty much USELESS upgrade, the money can be spent better places to give you more power
Moderator
The stock unit will hang on to higher power (air)
levels than the 85mm Delphi units. 511g/sec vs
460g/sec or so, at 12KHz. Minus the screen the
stock unit is not a meaningful restriction, no more
than the TB or stock manifold. The cheapest 85mm
you are going to get is a used truck MAF, pop the
screen yourself, buy the harness adaptor and maybe
a bit of 3.5" ID Fernco hose (this being what comes
with the SLP MAF, half a hose cut w/ X-acto knife),
tune for the different calibration and enjoy the roughly
0% difference.
Fat pipe: better. Fatter than you can use effectively,
for a big price tag: not better.
0% difference.
