need help clutch falls to the floor
sometimes when i get in my car and i push the clutch in it falls to the floor then when i check the fluid its almost empty, this happeened like twice, any suggestions thanks
I'd say it's the slave, time to drop your trans and swap the slave out. Same thing is happening to mine, eating fluid, clutch going to floor, yada yada yada, and I got the same answer- slave.
that is a hydrolic problem, and a new slave should take care of the problem. If your clutch has some mileson it I would replace it as well while you are there, that way when you start modding it you won't have to worry about the clutch for a while.
its a spec stage 2 with 2500 miles on it so replacing it with another clutch isnt happening at this point in time, so how much is a slave cylinder? and how hard is it to install? anything else i would need for that install as far as parts?
