Which lifters should I use?
I have Absolute Speed stage two heads milled to 10.8 compression, stock length pushrods, and a TR227/224 cam w/ a .569/.563 lift. I need to know which lifters would work the best: gm lifters, comp cam 850, or comp cam 875.
Re: Which lifters should I use?
Go to www.summitracing.com and order the crane lifters.Comp no longer offers lifters.I believe they are 179.99.They are reworked GM lifters.Be sure to get the right ones for your block year or they will make more engine noise.They have them listed for all years.
