Anyone Use This Comp Cams Adj. Timing Set?
So anyone use this?
http://www.compperformancegroupstore...y_Code=TMNGADJ
From here?
http://www.thunderracing.com/catalog...vid=3&pcid=222
The timing gear is rubbing against the 4 camshaft retainer bolts. I don't know what the problem is. The bolts are torqued down to specs (18 lb ft.) No, I don't have it on backwards or anything idiotic like that. I guess I will call both Thunder Racing and Comp Cams Monday. Hope I don't have get a slimmer retainer plate. Anyone have a clue what's wrong?
From here?
Originally Posted by RrCoX22
So anyone use this?
From hear?
The timing gear is rubbing against the camshaft retainer bolts. I don't know what the problem is. The bolts are torqued down to specs (18 lb ft.) I guess I will call both Thunder Racing and Comp Cams Monday. Anyone have a clue what's wrong?
From hear?
Originally Posted by ShevrolayZ28
Any chance you have it on backwards?
i just don't get it why it's rubbing on the bolts
What's a Sticky?
ha ya right... do ride on the short bus?
well i've searched and searched all night every possible site i could find and found really nothing for addressing the problem, just found posts where they fucked up their motor due to the gear hitting the bolts... this is insanely irratable. only thing i can think of is that either the cam is spaced back to far or that it's some how short in length.
can't believe no one has ever had this problem (especially with an overplayed timing set) with a way to fix it.
LS1 Tech Veteran
Why don't you call Comp's Customer Service. I have their adjustable timing set on my engine and I've used it on two cams with no problems.
Steve
Steve
