Using Cold Welds on Exhaust...
Is it safe to use cold weld epoxys (JB Weld and Quick Steel) on exhaust manifolds (headers). I have a friend with a hole in his passenger manifold and its a tough spot to weld while there installed so I figured I could just use the epoxy to cold weld it. Do these epoxys withstand the header temps or will they just last temporarily. What steps should I take if it will work and what is the best way to get a strong cold weld? Thanks a ton in advance...Josh.
i dont know but a freind of mine had a cracked radiator and he used cold weld to repair it and even though the car overheated (car had problems) half a dozen times the cold weld never let go or leaked.
i know a radiator doesnt get as hot as an eghaust manifold but it might work then again it might not because of expansion and contraction rates between the two could be to great and might just pop the cold weld right off.
Originally Posted by KevsfastZ
I believe that JB weld is only good up to 500 degrees, my boss used some to fix an exhaust leak on his car and it just crumbled after a few days.
Kevin D
Kevin D
do you have headers or the original manifolds?
i thought you arnt supposed to weld cracked manifols because they will just crack again.
if you have to remove the manifold to have it welded why not just buy a used manifols off someone here and install it and save on the welding alltogether.
1 Post
There are several types of JB Weld.
I used the regular stuff on a BBQ lid that had an hinge broken off when the wind blew it over. It let go the first time it heated up. Melted like thick wax.
I wouldn't think the stuff would work on an exhaust manifold.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
www.tptools.com carries the POR 15 line. they have an epoxy that works on manifolds. about $15
