pascal
02-02-2003, 03:10 PM
chev12bolt or ford 9 inch ,ordering diff. tomorrow from moser.is saving 25 pounds dead weight worth 500 as 12 bolt will be strong enough? please help with advice , thks.
M3EATER
02-02-2003, 03:37 PM
Are you road racing or drag racing?
The unsprung weight is more critical in the road racing. For drag racing, any weight is important. Also, the 9" has a greater pinion angle which means more frictional loss.
I'd say, that unless you're pushing some BIG power & running slicks, a well built 12-bolt should be fine.
Gordon
www.provenperformanceconcepts.com (http://www.provenperformanceconcepts.com)
<img src="http://www.provenperformanceconcepts.com/PPC%20BANNER%20468x60.jpg" alt=" - " />
If your picky and like to do different gear combos and set up your own gears. Then the 9 inch is the way to go.
