priming motor????
Old 07-30-2006, 12:19 PM
whiteLS1's Avatar
Default priming motor????
before starting up a new motor how do you prime it with these motors?
the old motor you could just hook a drill to the distributor and spin it up but thats no longer an option
thanks for the input
Old 07-30-2006, 12:23 PM
slowpoke96z28's Avatar
there is an oil galley plug at the left front of the engine. it requires a pressure luber and an adapter to fit the hole(M16 by 1.25 i THINK. don't quote me)
Old 07-30-2006, 12:43 PM
GOaT Cheese's Avatar
There is also an adapter that threads on where the oil filter goes, and uses a pressurized oil tank for priming.
Old 07-30-2006, 02:00 PM
nvmy2000ss's Avatar
Default Priming
When I did mine I pulled the plug wires off the coils, Then turned the motor over until I saw oil pressure. May take a few times but you should see it eventually.
Old 07-30-2006, 02:25 PM
jermzz's Avatar
I hope you pulled the fuel pump fuse, too!
