90 degree coupler from throttle body to maf
i need a 90 degree coupler to go from my throtle body to my maf
where can i gte one and what size...the maf looks to be 3.5 but the trottle body looks to be 37\8 4 inch looks like it will be way to big?
need one asap
lil help
thanks
only a few more parts to go
need one asap
lil help
thanks
Originally Posted by Ryan K
TTi makes a silicone elbow, I have one on my car, you might give them a call.
Ryan K.
Ryan K.
cool ill call george in the morning
i had one with my tti street kit but gave it up when i sold it...should kept i guess oh well
Restricted User
try calling billy at TRTturbo, i bought a rubber 90* elbow he had laying around cuz i was in a hurry but im sure he has silicone stuff like the one STS uses.... his # (817)-703-3750 good luck hope this helps
I upgraded a while ago, I still have it but I don't know where...
Ryan K.
Ryan K.
caugh i need it bad
if you would happen to stumbel apon it
ill buy it!!!
last part i should need to get this bad boy up and running
11 Second Truck Club
If it's the same as the trucks...the TB is 4" and the MAF is like 3-3/4"...
you can also, to get by until you get a reducing coupler...make a "bushing" out of a piece of hose to go on the MAF but under the 4" hose...clamp tightly and it will hold...
from the above website:
wouldn't ya know it...I checked because I need one as well...
I did the "bushing" until I can get one...no leaks...
3.75"/4.00" Blue 4 ply Polyester Silicone Hose Transition Reducer
$29.38
Currently out of stock and scheduled for production
$29.38
this is a quicker and less expensive fix...better than the "bushing", but same result...
Reducing Insert 4" OD to 3.75" ID
This reducing insert adapts a 4" ID intake hose to a 3-3/4" OD pipe. You install it in the end of the 4" rubber elbow or hump hose, and then the 3-3/4" intake pipe fits in the hole.
Code: 40R375
Price: $7.23
Shipping Weight: 0.20 pounds
4 available for immediate delivery
intakehoses dot com
Code: 40R375
Price: $7.23
intakehoses dot com
thanks for the ino emialed him got right back to me ordered one on its way with clamps!!
great price
crossing fingers its everything it says to be when it gets here
Originally Posted by ChevyNo1
go to www.hightempsilicone.com
