cluth fluid?
Old 07-31-2006, 12:49 AM
Eiyse98ls1's Avatar
Default cluth fluid?
whats the best way to get all this fluid out? the fluid in the res. is dark in color. also at times i have to depress the pedal pretty far down to change gears.
thanks in advance
Old 07-31-2006, 02:03 AM
Starz T/A 17's Avatar
best thing to do is suction the old fluid outa the res. out and add freash fluid then bleed the clutch and keep adding fluid till clean fluid bleeds out.
Old 07-31-2006, 03:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Crack the bleeder on the slave and add in the master resevoir. Let gravity do its job.
Old 07-31-2006, 03:13 PM
Eiyse98ls1's Avatar
the bleeder on the slave is located right above the braided line? on th etrans. driver side?
Old 07-31-2006, 08:28 PM
ls1 jeff's Avatar
Correct.
Old 07-31-2006, 11:40 PM
Eiyse98ls1's Avatar
i tried feeling for itbut couldnt locate. hoe is it positioned (sidetoside) or (up and down).
