Whats involved in forging an LS1? in garage...possible?
Old 07-31-2006, 09:51 AM
LS1Tech Sponsor
Superman09's Avatar
Default Whats involved in forging an LS1? in garage...possible?
Well doing an STS kit this winter and wondering if i got the necessary parts to forge my motor, pistons rods, etc, how hard it would be? This would be with the assistance of a mechanic. I know motor has to be pulled but im jsut curious whats involved in installing the new items, what tools are needed, etc. Can it be done? Very easy to screw up? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 07-31-2006, 09:54 AM
Joel_SS's Avatar
Go get the lastest issue of GM High Tech Mag. I gives you step by step how to build an LS1 in your garage and al the tools you need.
Old 07-31-2006, 09:56 AM
LS1Tech Sponsor
Superman09's Avatar
ok thanks!
__________________
Old 07-31-2006, 10:00 AM
Boostaholic's Avatar
You will need balancing done, I redid my 408 in a garage just a few weeks ago and it turned out great
Old 07-31-2006, 12:55 PM
SVT THIS's Avatar
I would just buy a used LS1 shortblock and have a basic cleanup done on the block, crank, etc. Then, build it up in your garage with forged pistons, connecting rods, rod bolts, etc etc. You could still drive your car while building the motor and the downtime of your car will only be the time it takes you to swap the motor in. There are several 346 build ups over in the Forced Induction section that could give you an idea of what parts you need to use. Good luck brother, I'm right there with ya!
Old 07-31-2006, 02:39 PM
LS1Tech Sponsor
Superman09's Avatar
thanks, i will probably end up getting a forged long block down the road as i dont have heads or a cam yet either, just seeing what was really involved in doing it your self to a current block. Thanks for the info!
__________________
Old 07-31-2006, 05:40 PM
SVT THIS's Avatar
I'd get just the shortblock. You will save you a lotta money and can build it to your specs.
Old 07-31-2006, 06:08 PM
Tri5Nerd's Avatar
