front runners?????
front runners?????
i have a 96 camaro with 15in weld prostars on the back but i want front runners......what size will fit with the least amout of mod? can i run the 15 in front runners welds?
thanks.......
thanks.......
15x3.5" with 1.75 BS is what most run. You can either grind the front calipers for them to fit or run a 5/16 spacer. I would suggest longer wheel studs if you are going to run a spacer.
