DRC built TH400
DRC built TH400
I'm STRONGLY considering a t56 to TH400 swap but am NOT very up to speed on Auto's or TH400's so I have a few questions. There's a sale/trade pending so I need info kinda quick.
1. How many gears does a TH400 have?
2. With stock gears from an M6 (3.42's??), will driving 60mph put me in the neighborhood of around 4k rpm?
3. Will I be okay with stock M6 gears or should I go to 3.73's?
4. DRC...who are they and what's their rep?
5. Will a hurst 1/4 stick shifter fit with the manual leather shift boot?
6. Will a Spohn Chromoly DS that has a 1350 U-joint fit on my stock 10bolt?
7. If the TH400 doesn't come with a transbrake, can I add one later w/o TOO much trouble?
8. TCI 3800 stall with a 224ish -> 228ish cam? Too much stall for that cam?
9. Valve body style? Automatic/Manual, Full manual, or Automatic? What's the differences and what's recommended for a DD with occasional track visits? I obviously don't know what it is.
9. Will I have to drill into my radiator for a B&M transcooler?
10. Gears...what gears are recommended for the TH400? Keep in mind this will see a lot of daily driving.
11. Electronic control? Will I be able to programmatically change shift points, firmness with HPT or EFI Live or is all mechanical and part of the shift kit?
Thanks so much guys!
1 3 speed
2 Not that high, I believe like 70mph would be about 3300rpm
3 I would stay 3.42s if you do alot of street, your losing od with the 400
4 no clue about drc
5 hurst should fit i saw pics somewhere
6 spohn offers different versions, just contact them
7 transbrakes are in with the vb, like 220 or so for a vb with a brake
8 cant really help ya here
9 manual vb and no need for a kickdown, but if you go auto vb, then you need to use a 93 throttle bottle with the hook up for the kickdown
2nd 9 lol) No drilling, they come with tiers that mount them or bolt it on somehow
10 You could go more... but no od so not great for hwy use with more than what ya got
11 its a non electric trans
4 no clue about drc
With a 4000 stall and 3.73 gears I am around 3100 at 60 MPH.
I'm using a 4k stall on a stock cam LT1 so.......
If using the car as a daily driver keep your rear gear ratio 3.42 or below.
You can use just about any shifter you want but you will have to fabricate it into the car if you know what I mean. I run a B&M Pro Stick and just went the easy route and run an aluminum cover on it.
I have a reverse manual valve body with a transbrake, the brake is not hooked up yet so I am not tempted to grenade the rear. I love the RVMB but you have to pay attention, its just like driving a stick car, you shift it all the time.
Reverse manual valve body basically switches the direct of 1 2 3 gears. 1st is where 3rd is and you shift back from first instead of foward. Also you take full control of the shifting, like a manual with no clutch. I'm using one on my 400 with a ratchet shifter.
Thanks and sorry for the newb questions. Ask me about the t56 or it's clutch hydraulic's and I'll tell ya almost anything you want to know
Originally Posted by Xtnct00WS6
the manual valve body sounds freaking sweet! I'm not so sure that going 3200ish RPM at 65 will be much fun when I'm on the highway everyday.
My 3100 RPM is with a 26 inch diameter tire and 3.73s. With street tires traction is fleeting....... I have to run a DR to even think about hooking up.
Race your car!
I calculated it out, that my car with 4.10 gears and stock hieght tires will be 3500 at 65 with no converter slip, so it's reasonable to think that it will be about 3700. Now that seems like alot, but I am planning on putting 28 inch tires on the back, ans will be swapping to 3.73's when I put the bottle on my car as I'll be running out of gear with the 4.10's that I am sure of. Those 2 factors, plus the fact that my car is NOT a daily driver by any means and only sees a highway trip of about 20 to 30 miles every now and then is why I am not concerned. I do however, plan to drive it to the track, a 80 mile trip one way once I have the car sorted out, so that I can say I drove to the track, blasted off a 10.xx on motor on pump gas, and drove home. Keeping speeds down to about 55 also helps the RPM situation a ton, I don't remember the exact #, but it was a good amount.
If you are putting the th400 in a daily driver, I'd suggest 3.42 or 3.23 gears, and a stall that's 3500 or less. They won't be the optimum for the track, but will make the rpm that the car is at all the time alot more livable. The only other option, is to go to a taller tire
Race your car!
Originally Posted by Zombie
3.5 gears, 25.6" tall tires = 3500 rpms at 65 mph.
What you are saying is a little disturbing to me... as with my M6 and the 4.10's, 65 mph in 4th (1:1 like th400 3rd) is about 3500 rpm.. there's that much converter slip to make the car run up to 3500 with 3.5 gears? What kind of converter do you have? I'm hoping mine's got alot less slip then that... it was built to be put behind a 1100 hp nitrous ls1 setup in a 3200 lb car and stall at about 5000, but be as close to locked at the big end as possible, we're hoping that with my 500 rw that I'll probably be around it should eb more like a 4000 off teh bottle, and with a 150 hit about 4600.
So I can drive on the highway at 65 mph while ONLY at 2500 rpms if I have 2.75's? The stall would have to be pretty small too wouldn't it? Something in the area of 3000?
Isn't the car a slug in first with 2.75's and a TH400?
Thanks!
Thanks!
