Automatic Transmission - Will a 4l60E bolt into a Old Small Block Chevy???
QuickSilver
07-31-2006, 10:04 PM
I need to know if a 4L60E will bolt to a Gen 1 Engine?
I have 2 trans to work with a 94 out of a LT1 and a 99 out of a LS1 car
Also who make a stand alone controller for the 4L06E in a non Computer car????
Thanks
Josh
8a8mfh
08-01-2006, 05:42 AM
A non LS1 transmission will bolt right up. TCI and some others make a controller.
QuickSilver
08-01-2006, 05:51 AM
kinda thought the LT1 Bolt patern was the same as the Gen1's.
Also the trans is a 94 that will still need the controller right? I was reading some lastnight and i think one site said only the 87 and up and electronically controlled.
I personally thought they all were.
Josh
gd1996
08-01-2006, 02:40 PM
A 93 is not electronic, 94 is, but 94 I believe is unique with the plug, then 95 has another. So 94 yes you need yes you need a controller. 87 and up maybe be the lockup for the converter, but not fully electronic.
01WS6er
08-01-2006, 02:56 PM
I belive in 87 was when GM went to the 700r4 which needs a power source to power the TCC solenoid. I just sold a 94 Z28 trans (LT1 eng) and it had the same plug as my 95 silverado did.
8a8mfh
08-01-2006, 05:37 PM
700's had a small square plug for the tcc lockup starting when they came out in 1982.
In 1994 the 4L60E came out and have the big round plug for the lockup and the other controls.
QuickSilver
08-01-2006, 09:32 PM
thanks for the help guys. I have a 94 4L60E that is going into a 68 Chevy II with a built 230 I6. Should be a fun project.
Josh
lt170chevelle
08-03-2006, 04:12 PM
yeah the ls1 style 4l60's only the top 4 bolts bolt up.and the lt1's will bolt right up.and you will have to get a computer to run the 4l60e no way around that
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
