Northwest Members WA, OR, ID, MT, WY, SD, ND
Thinking about new Moser 9"
Old 07-31-2006, 10:29 PM
99blancoSS's Avatar
Default Thinking about new Moser 9"
Been thinking about a new rear for the car. Not going to repair the current one if it goes out again and it seems to maybe be on the way. So a Moser 9" looks to be the choice. The big question is the diff. Should I go with a tru-trac or a detroit locker? Leaning towards the locker.
$2500 delivered from EPP isn't a bad price.
Old 07-31-2006, 10:49 PM
Mikey 97Z M6's Avatar
Personally, I'd buy the axle/housing package and build your own center chunk or have a center chunk built locally. You could get that package and put in a POS center chunk that would be stronger than the stock 10 bolt and you'd have less than 1500.00 into it. But then again,,,, what the heck do I know lol.. ?
I have a link (somewhere) to a place that was selling the axle/housing packages less than 900. I'll see if I can dig it up if you're interested.
Mike
Old 08-01-2006, 03:34 AM
LSxChevelle's Avatar
That is the way to go. Just buy the housing and axles. Find a used center section and save a lot!
Old 08-01-2006, 09:09 AM
WAHUSKER's Avatar
After installing one, I wouldn't even consider buying a unit that wasn't specifically designed for an F-body. Unless you are a heck of a welder & fabricator.
As for which posi, it's all about what you plan to do & what you can live with. A locker is stronger, but it's going to make noise going around corners too. A spool is stronger yet. The True Trac is supposed to be the best of all worlds. When my Eaton/Auburn posi goes (whichever it is) that is what I'm putting in. They are strong enough to hold up to drag racing, and yet turn free enough for road racing.
Old 08-01-2006, 10:07 AM
Mikey and I were saying to buy a housing and axles for an f body and then get a center section yourself elsewhere.
Old 08-01-2006, 10:48 AM
Tranzor's Avatar
I would NOT get a locker for an M6 car... I'm learning that the hard way. The slack in the drivetrain is too much for an M6 car on a drag strip launch... hits the tires all at once... it would be a great compromise between a posi and a spool for an all-out A4 drag car that can pre-load the drivetrain, but for us who have to go from static to full RPMs, not so good. I can only hook when they lay the VHT down... no VHT, forget it, won't get better than a 2.0 60' even on my 27" ET Street radials.
If I had to do it all over again, I would have gotten a spool and been done with it. But then again, I don't drive my car hardly at all on the street anymore... so a spool wouldn't bother me one bit.
Old 08-01-2006, 10:59 AM
99blancoSS's Avatar
Good info guys. Wasnt real sure about the locker, I just want this to be as bullet proof as possible. As far as buying the stuff seperate I'm not real sure what to buy so I dont want to make any mistakes. I know a fully assembled unit will come with a warranty and thats kind of appealing to me but so is saving money.
Question for anyone who can answer it. If my posi was going out would it rob me of power? Trying to look at and figure out why my trap speed was so slow. At my power level I should be trapping around 120 I'm told. I found a broken egr tube, could that have been the only cause? Sucking air before the 02 causing it to run rich maybe plus it was vibrating back and forth maybe causing KR as well?
Old 08-01-2006, 11:05 AM
Tech Addict
Rokko's Avatar
I can vouch for the no traction on jason's car, I was lined up behind him 3 times last friday and it didn't hook very well at all. Course everybody was spinning at the launch on the first two time hits.
Old 08-01-2006, 11:08 AM
fastest94v6's Avatar
Mike
you can beef up the stock 10 bolt all you want, but it still won't be able to compare to a 9" or a 12 bolt simply because its smaller...
Old 08-01-2006, 11:18 AM
Rottluver's Avatar
and because it sux!!!!!!!!!!
Old 08-01-2006, 11:44 AM
Tranzor's Avatar
I don't think it would cost you any speed... I broke the spider gears in my Eaton HD 12 bolt posi on the launch when I ran one of my fastest times (12.17 @ 114 and change).
At least around these parts, the trap speeds and ETs tend to be down a little bit from what you see people post in other parts of the country.
Old 08-01-2006, 11:52 AM
Rottluver's Avatar
That is weird cuz I picked up over 2 MPH on my trap speeds at PR.....although the only other place I ever raced at was at some pretty serious elevation........
Old 08-01-2006, 11:56 AM
99blancoSS's Avatar
Something has to account for my miserable trap and et. Tom had a camaro with 40 less hp than me on his dyno run an 11.9
My best was 13.39 at 108 with a 2.47 60'. Thats slower than stock.
Old 08-01-2006, 12:14 PM
Tranzor's Avatar
The complete setup is what makes drag racing... which is why you will see a lower power car often take a higher power car to the woodshed.
Suspension is huge at your power level... without the proper drag racing suspension, tires, etc, you aren't going to run good times.
Also, what kind of a launch are you using? For an M6, you really have to hammer that thing off the line and hook in order to run a good time. I'm talking 5+k clutch dump and a dead hook.
As for your trap speeds, don't know what to tell you... that does sound low, around here I would expect you to trap around 117, maybe 118 or so... 120 is probably a little much to expect around here. Doesn't have to be the car though... could be the driver. How are you shifting? Hard? Easy? Lifting foot off gas? What RPM are you shifting at? Might be leaving a couple mph on the table if you're shifting too early.
Also, with your power level I would think a 4.10 gear would be optimum... 3.73s will probably drop you right out of your power band on each shift.
Here's my advice for a fellow M6 driver... 4.10s, drag racing suspension, a drivetrain that will take a 5k+ clutch dumps all day long and not blink, tires you can dead hook on, and shifting like you're trying to break something. You'll run some good times, or blow something up, guaranteed.
Old 08-01-2006, 12:38 PM
99blancoSS's Avatar
Well I'm not hooking off the line but I dont think you can drive it any harder without breaking something. Trying to shift at 6k. I know my suspension isn't setup for drag racing but 13.39 at 108 is still not right. I might not see 11's without the juice but 12's shouldnt be out of the question at all. Maybe my o2 sensors are going as well? I dont have a WB so I really dont know what the af is other than what it dynoed at in feb.
Old 08-01-2006, 12:46 PM
Tranzor's Avatar
I'm thinking 6k is too low... get yourself a shift light (if you don't have one already) and set it for around 6300 rpms. This should mean you make the actual shift at 6400-6500 rpms. With ported heads and a relatively mild camshaft, that should be about what you shift at. If you're shifting say 500 rpms early, with 3.73 gears, you really are taking yourself way out of the powerband on each shift... and then the car has to climb back into it (which it isn't doing as fast as it would with 4.10s).
I say give the increased RPMs a try next time out... might surprise yourself by picking up quite a bit of MPH and some ET to match.
Old 08-01-2006, 12:49 PM
Talking about The Beast and Mark...
Old 08-01-2006, 12:52 PM
99blancoSS's Avatar
I bought a tach w/light. New mini monster but I'm having trouble setting the light. Already talked to Auto Meter about it and they admit to a problem with the first batch but think I can work thru it and not have to return it. JMFL ! And then the egr tube broke of the header so I need to get that repaired. I should be racing again a week from friday hopefully.
Old 08-01-2006, 12:55 PM
99blancoSS's Avatar
This is the dyno. I think it drop to 4k rpms when I shift, not sure not really looking.
Old 08-01-2006, 01:15 PM
Tranzor's Avatar
Looking at that graph, if you drop your RPMs to 4k on your shift, you're going down to what, 280rwhp? Yeah... that's not good. That means you're trying to climb a long way back to your 440 rwhp peak. You want to stay as close to that peak as possible... and from the looks of it, you're peaking right about 6000 rpms, maybe even 6100-6200. Judging by that graph, I'd almost increase that shift point up even further than I said originally... maybe making the shift at 6600-6700 rpms. That would probably take you down into the 5k range on the shift, which would be more ideal.
