General Maintenance & Repairs - Maybe a dumb question Brake and ABS inop light
Swedez28
08-01-2006, 10:19 AM
Lately my BRAKE and ABS INOP light has been coming on. It doesnt stay on all the time and after turning off engine and restarting it goes off! WTF!
Anyone have this problem and what is it really trying to tell me(other than the obvious). Thanks for the help in advance! :hail:
phengtfang
08-01-2006, 12:23 PM
i have the same problem. it happened like a week ago, and i dont know the problem either. help anyone?
contraststriker
08-01-2006, 12:43 PM
sand and retighten your grounds, ABS INOP can come on if there's even a slightly weak contact.
2001whiteSS6spd
08-01-2006, 04:39 PM
Different size tire diameter will cause this problem, and that looks to be your case.
Eric
Swedez28
08-02-2006, 09:16 AM
Eric
I could understand that if it happened right after I changed the wheels and tires but, I did that over a year ago! Wouldnt it have come up sooner than now? Its just strange that its happening now. Anyone else?
EDS01SS
08-02-2006, 10:47 AM
remove your rotors and check the wheel sensors for metal shavings.The shavings will block the signal to the sensor and cause the problem you are having.Use a magnet and remove the shavings from the sensor if they are covered.Also check the rear wheel sensors.
1badragtop
08-02-2006, 10:48 AM
When it happened to me, my brake fluid was low. FWIW.
leadfoot4
08-02-2006, 12:41 PM
Excellent advice..... I had a similar problem for several monts, and it was puzzling. I finally used a soapy water solution applied with a pressure gun to blow out the brake dust, and other crud from the wheel bearing area, just doing a "spring cleaning". Problem sudenly went away.... Apparently brake pad dust can set up a magnetic field that the sensor picks up.
Pewterpower
08-02-2006, 05:25 PM
It happens to me when it gets really hot and I've been in alot of stop and go traffic. Once they've cooled a bit, they're fine.
Swedez28
08-02-2006, 09:05 PM
I will try removing the rotors and cleaning the sensors. That sounds very logical. I will do it in the next few days. Thanks to all for the input! :hail:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
