I need pics of SW SS LTs from the guys who have 'em.
Originally Posted by bene
I've search both on kooks and SW SS headers... I haven't heard any problems on installation/fitment on SW headers while on Kooks, there's a few. Besides, Kooks don't offer 2.5" collector.
Also I am sure they will custom make a 2.5" for ya.... If you really want...
Not the best pics in the world...but hopefully they will help you a little.
As you can see in the first picture...the Y pipe caused us some problems. Note how the bracket doesn't line up with the stock location...we landed up weling it on there and painting it to make it look a little better. Definitely no clearance issues on the passenger side though. We had to cut out about an inch of the Y-Pipe on that side to get everything to fit.
Here's the final solution to the Y pipe banging the floorboard on the driver side problem. I used this mufflex hanger, but due to the location of the O2 bung on the Ypipe, we had to cut the mufflex hanger apart, and weld it back together the other way around to make it work. We also had to squash the Ypipe a little by stuffing a piece of wood in betwee the floor and the pipe and letting the car down slowly. But now I have no issues with banging at all.
Just an overview of the underside of the car after the torque arm was installed, it has a bit of the exhaust in it so I included it too. The stock crossmember that you see in the first pic is now gone...obviously, but it never really posed a clearance issue on my car.
The headers themselves were not that bad to put in. We took the plugs out, and had to remove the starter and jack up the engine on the passenger side if I remember correctly. The headers only took about 2 hours, we did use a lift though. The Y pipe took forever!
Hope this helps.
If you want more specific pics, I am gonna have to go through my other pics and upload them or even take new ones.
Hope this helps.
headers themselves fit good like the others were saying....great quality...only problem im having now which wont be an issue with your TD's is getting the y pipe in...seems like with my stock I-pipe that the y is a little long, but i will be looking at everything again tonight. The whole system tucks up better than any system ive seen. SW told me the system was desigened to work with the eibach kit. I have an old post with a few pics of the headers. no installed pics yet
