Dyno tune #'s
Dyno tune #'s
Got the call today from Larry at Speed inc. today that the car was ready for pick up. She put down 619.81 RWHP and 529.70 RWTQ with 99 degrees in the shop . I couldnt believe the numbers, i was shocked. Im kinda pushing my luck with 11.1:1 compression and 10 psi but hey, if she blows i will just have to upgrade . I didnt get a chance to beat on it today since the weather in chicago is sitting at 100 degrees and i wasnt feeling too lucky. I would like to thank Speed inc for awesome and quick service, can not be more happy.
Nice #'s man...You're brave making that boost on 11:1 CR w/o at least some alchol to help out a bit. Anyhow, you'll def like the new power, esp. on the street. Are you on stock bottom end?
Yeh, sounds like a plan. Good luck with the car. Your HP is identical to mine but I have a different setup(6.0L heads, blower cam, alky injection, 10psi on a P1SC, 347 LS1 9.5:1 CR).
