Suspension & Brakes - are LCA relocation brackets a must?
tbird31
08-02-2006, 11:54 AM
i have a set of BMR lowering springs and i was just wondering if it is a good idea to get a set of LCA relocation brackets? I don't have enough power really to turn over the tires much so i'm not really worried about wheel hop. Just wondering if it would be a good idea to get them?
thanks in advance.
Reject
08-02-2006, 03:18 PM
i would think so since you are reengineering all of the angles of the rear suspension.
tbird31
08-02-2006, 06:29 PM
thanks man
anybody else have anythign to say? with 19 views i figured someone else would post up.
Duffster
08-02-2006, 09:09 PM
I would think Panhard a tad more important, but yes, if you're messing with the rear suspension, LCA RBs wouldn't hurt.
UMI?
RrCoX22
08-02-2006, 10:15 PM
why the hell wouldn't you do it? it minimizes any traction problems and gets your geometry angles back to normal with a lowered ride
leadfoot4
08-03-2006, 08:20 AM
UMI?
I agree.
Michael02hawk
08-03-2006, 06:10 PM
If you want to build the suspension up correctly, then Yes, you need them.
If you dont care, then nope.
shaun
08-03-2006, 06:36 PM
made a big diff on my car.before i had them my car would just light up the tires from any speed in 1st and some of 2nd now it still spins a little but its a big improvement. and mine are adjusted on the middle hole but im going to lower them to the bottom hole later and see if it helps
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
