Ls7 Cluth Question
Old 08-02-2006, 12:40 PM
B&B01BlkSS's Avatar
Default Ls7 Cluth Question
I currently have the S.L.P. clutch kit, see below. The clutch is now bad and i was wondering if any one knew weather or not I could use the billet steel flywheel it came with, with a new Ls7 clutch & pressure plate kit.
Here is what I got:
Clutch Package, 1998-02 LS1 Camaro/Firebird/1997-04 C5 Corvette/2004 GTO Heavy-Duty
This high-performance clutch package is compatible with any 1997-04 LS1-/LS6-powered Camaro, Firebird, GTO, or Corvette (manual transmission only). It comprises an LS6-style OEM clutch disc and self-adjusting pressure plate (introduced on the 2001 Z06 Corvette and used in all LS1/LS6 applications starting in 2002) mated to an SLP billet steel flywheel. In addition to greatly enhanced strength, this flywheel offers an eight-pound weight savings over the factory unit. The LS6-style pressure plate offers 20% more clamping force than a stock pre-2002 piece, and the disc features a heavy-duty spline. Your engine will rev faster, and your 1/4-mile times will drop noticeably. Shipped complete with installation instructions and new crankshaft pilot bearing.
NOTE: 2001 Z06 Corvettes and all 2002-up LS1/LS6 vehicles were factory equipped with the same clutch and pressure plate included with this package. To upgrade one of these vehicles, simply install SLP's billet flywheel (#60037
Old 08-02-2006, 12:59 PM
CaliboyTA's Avatar
no. you need an ls2 flywheel
Old 08-02-2006, 01:08 PM
BIG_MIKE2005's Avatar
^^agreed. For the LS7 pressure plate/disk to work in a f-body you must either buy a LS2 flywheel to go with it or get the complete kit.
Old 08-02-2006, 01:26 PM
Rescue Ranger's Avatar
What did you buy a SLP clutch kit for??
Yea like they said, for a LS7 clutch to work you need the LS2 Flywheel (now ls2/ls7 flywheel is same part #)
