M6 To Th400
M6 To Th400
I bought a 400 and now i want to put it into my current 2001 m6 t/a
I need to know what I need to find as far as a flywheel, crossmember and
will the m6 pedals work or do i need to buy a a4 pedal set. Also will the 400 bellhousing work or does that need to be changed. Can someone come up with a good list of stuff I need.
I need to know what I need to find as far as a flywheel, [I bought my flexplate from TCI. It is SFI approved and well worth the money. Its made specifically for the TH400/LS1 combo] crossmember [you can modify the existing one by creating oblong holes where the crossmember mounts to the body. I bought one from BMR though, also a worthwhile investment] and
will the m6 pedals work [yes, they'll work, but I'd rather have the A4 pedals]or do i need to buy a a4 pedal set. Also will the 400 bellhousing work [it works, there is at least one bolt that you will have to leave off] or does that need to be changed. Can someone come up with a good list of stuff I need.
