Gears & Axles - posi and limited slip
98hardtopZ
08-04-2006, 12:06 PM
is there a difference between the two? i was told there was but never explained so i came here for the answer..
TA TECH
08-04-2006, 12:18 PM
Limited slips are posi's! Only real all time posi is a spool.According to what limited slip ya buy some have clutches and some have gears!Just have to reseach it alittle!
lt1formula2000
08-04-2006, 12:21 PM
I guess all axle/differentials that tranfer power both tires could be called a posi. While a limited slip it just a type of posi. Like all motors with 8 cylinders arranged in a V are called V8, and the LT1 and LS1 are just different V8's
98hardtopZ
08-04-2006, 12:29 PM
i could have sworn i read somewhere that some guy said he had posi in his camaro and people argued up and down that no, he had limited slip and there was a difference.... but anyways, thanks for the answers
mzoomora
08-05-2006, 08:30 AM
Posi is nothing but GM's brand name from the 60's for limited slip. They used to call it Posi-traction. Other people called it trac-lok, power-trac, traction-loc, sure-grip, etc. They are all limited slips. A spool is not any type of posi because it isnt a differential at all (since it doesnt allow different speeds to each wheel- which is what the word differential or limited-slip differential implies).
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
