motron injectors
motron injectors
I have efi live.
anyone have any ideas what to set the small pulse adjust, injector timing, injector timing trim, injector pulse width voltage adjustment, default pulse width, min inj pulse width to?
I think I have the injector pulse width voltage adjustment good to go and the IFR good to go.... just having issues with idle being rich and VE isn't affecting it, also midrange goes lean under throttle when sitting and hitting the gas a little, but goes back rich up high.
anyone have ideas
anyone have ideas
are you running the stock cam and just bolt ons?
can you post up the IFR you used?
having issues at idle that caused it to run rich as hell 10.5 and 11.x AFR at idle
i know for a fact its got something to due with the injector timing tables....
there is 1 table that affects the pulse width of the injector directly (at least more than the others) and thats the one i need to add like .1 to at a time to get the AFR down to around 14.x
does someone know if its the injector timing? i think it is...but i know there are the other tables that affect it and add to it
here are 2 scans. one where the timing is 1.9ms and then 1.6ms
that is the table(s) that i need to add a little to and see what happens
these injectors will not go to low enough a pulse width for idle , now raised it to 950 and i have no problems...
probably going to get some 42# injectors so they won't be as big for my setup
