Advanced Engineering Tech - hone pattern for hellfire rings???
the paper included with the rings says nothing about the needed cyl finish. anyone know what is required???
WickEdSix98
08-06-2006, 11:22 AM
The same as all other rings.
airflowdevelop
08-08-2006, 08:44 PM
I'am gonna have to say....emmm No to that one. The days of using a 501 stone for all types of rings, are gone with flathead fords.
What ring package are you running, Hellfire only represents the top ring construction. You would need to know the entire combination to properly choose the correct surface finish.
Why in the world are you running these rings anyways? I would hope, anyone who would be playing with this type of ring, would know how to properly prep the bores? If your machinist is unsure...you either need to find another one, or have him contact SP.
Dennis
you would think that the leaflet included with the rings would specify the cyl finish needed. I am running the standard 4.005" bore hellfire boxed set from speed pro.
why would I run them???....402, twin 76's, 22psi...do I need to go on??? :D
LOnSLO
08-08-2006, 10:10 PM
You could always finish hone with a 280 grit. I don't think these rings require a plateau hone, but others may disagree. It is a very tough top ring that will take tons of heat. The second and oil rings included with that set are standard Speed Pros. I would stick with a 280 finish.
airflowdevelop
08-08-2006, 10:38 PM
you can get the hellfire tops with any anterior ring package.
Your combo does not necessarily warrant hellfire rings. Normally they are only needed with nitrous motors that make more NA HP than your combo will total.
Yes, they are better than sliced bread...but if used improperly, will cause lost HP, and many other negative side effects.
Dennis
Cstraub
08-09-2006, 08:40 AM
If you want to ask the guy that developed the Hellfires you can go to his website:
www.survivalmotorsports.com Barry Robotnick is his name.
racer7088
08-12-2006, 11:26 AM
Its still a barrel faced top ring like your Moly rings are but with no moly to flake off if and when you detonate etc. It's also made of a tougher material that can stand more heat without losing tension. I don't run any different finish for them then on my Plasma Moly rings and have no problems at all. It's a conventional plateaued finish of course.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
