My brand New Racetronix Pump doesnt work
Old 08-06-2006, 11:12 AM
rippenhard's Avatar
Default My brand New Racetronix Pump doesnt work
Yep thats right. I purchase a Racetronix pump and wiring harness a few months ago and just got around to installing it and what do you know. The relay is bad on the wiring harness. Or at least thats what I hope it is. I tested the voltage going into the relay and it was good and coming out......Nothing! So now Im trying to get a hold of Racetronix to take care of this promblem. Im thinking I could most likely just go to a local parts store and pick up a relay myself and save myself a lot of heartache and time. Has anyone else had promblems like this with there Racetronix Wiring Harnesses?
Old 08-06-2006, 11:19 AM
MiaSSmaro98's Avatar
wow that sucks atleast a relay is cheap just go grab one at auto parts store
Old 08-06-2006, 05:39 PM
DrkPhx's Avatar
Are you referring to the Racetronix harness that plugs between the stock connector and body connector?
Old 08-06-2006, 06:56 PM
rippenhard's Avatar
Yes the relay on the harness is bad.
Old 08-06-2006, 09:17 PM
DrkPhx's Avatar
I had the same problem with mine. Took me countless hours to figure it, until I just plugged the stock harness in and the pump worked. I contacted Racetronix who told me to send it back, but I really didn't want remove all of wiring so I left the stock harness in.
Old 08-08-2006, 02:23 PM
rippenhard's Avatar
Well here is the update. I tried replacing the relay and of course it still doesnt work. Has anyone else had any promblems like this with their wiring harness or pump. I have checked voltage going in and out of the relay and still no power coming out, even after the new relay. I am about to just hook the pump up the the stock pump harness and try it that way.
Question? Do these pumps whine or make any noise when first turned on, like stock pumps do when they are priming.
Old 08-08-2006, 07:41 PM
VSGLS1's Avatar
Is the 12v signal there? Yes, they should whine when the ignition is on.
Old 08-08-2006, 10:29 PM
rippenhard's Avatar
Yes there is 12v going into the relay but not coming out.
Old 08-09-2006, 11:09 AM
iamsickofitall's Avatar
sounds just like my Racetronix harness/relay...i'm going to try another relay and see how that works out.
Old 08-09-2006, 12:33 PM
does it have a good ground?how about a 12v ignition source besides the constant 12v?
Old 08-09-2006, 01:15 PM
ZL1Killa's Avatar
i'm having different issues, mine will cut in and out of operating, i'm going to check all the connections tonight though and make sure that the pump is the issues and not wiring; if it is wiring and will re-wire the **** myself and make sure it is getting power
