How many have lifted ported 6.0L heads?
I heard tuning is the key to keeping these heads down. Along with L19 head studs. I also heard running a GM MLS gasket wont hurt either. So how many have lifted 6.0L heads? Let me know how much boost you were running, fuel and timing..
__________________
__________________
Originally Posted by NA$TY-TA
Vince,
Ported 6.0L heads, 6.0L MLS Head Gaskets, Normal ARP Head studs and 22psi so far. C16.
I believe Harlan was the same but with 30 psi..........
Kyle
Kyle
Originally Posted by VINCE
Wow!!!! I did not know you guys were running that much boost. Thats crazy!! I guess my L19's are added strength.
Yeah in my vid in my thread the 1st pass is 12-13 psi..... what i run with Pump 93... the 2nd pass is really the last pass at the track on 22 psi.... to be sure im safe fuel wise....
the 3rd 9.26 pass is on 20 psi.
Kyle
Kyle
Kyle
I asked the question not long ago as well... Harlan was the first to chime in... then PSJ, then others... these guys dont lift heads that are properly bolted on (you mentioned what needs to be done earlier). Made me decide to stick with 6.0's instead of going big money heads.
Not 6.0's but have lifted the AFR's...going to the L-19 studs and GM MLS now. The std ARP's and SDE gaskets aren't working. Everyone with the L-19's what you going to as far as ftlbs? Is 10% over-torque too much? Don't want anymore problems with lifting the heads and do not want to pull the motor for larger studs unless its the very last resort...
I have ported 6L heads (not milled), with the "dreaded" Cometic gaskets & ARP studs. (retorquing them is the key I think) So far I haven't lifted a head, but I'm just getting into the "serious boost" category. I was only making 8 psi before, and obvioulsy never had an issue. Now I'm at 12-14. My motor is 9.3 CR, with 14* of timing (was at 18 before) running a full tank of 92 octane mixed with 3-4 gal of race gas with good fuel pressure so we'll see.
LS1Tech Co-Founder
Maybe Intmd8 can post what my gaskets look like, he has my car. I ran only C16 and his tune when I was making runs. My first set of MLS gaskets from like 2003 had some etching or burn channels, but I was also fighting some FAST controller issues so timing might have been an issue.
Originally Posted by INTMD8
The gaskets look fine. Also, could you PM me with your piston dish and cyl head CC info so I know what your CR is going to be.
I'm running a Ross -20 cc dish , going to swap to some 72cc 6L truck heads (right now I'm running my stock ported heads). I don't have all the other info, as far as gasket thickness (is thinner or thicker better?) or deck height.
THANKS!
