Is my wastegate too small??
i have a tial 44 mm and im not sure if i need to go to a 60 but when my car blows off its a sputter not a pssssssssssshhhhhh like most turbo cars. I heard sputter is not good!
cAN a turbo expert chime in please!
The wastegate is not related to the blowoff valve.
Your wastegate regulates exhaust gas flow through the turbine wheel, and vents it into the downpipe when you reach full boost.
The blow off valve relieves pressure on your intake pipes.
Could you explain how your blow off valve is connected? I don't see what kind you have in your sig but I can tell you on my TIAL 50mm it did that because I accidently hooked it up to a source of vac/boost that was BEFORE the throttle blade, after moving it behind the throttle blade things are 100% better and I get a nice turbo car sound when the blade quickly closes on boost.
Originally Posted by MiaSSmaro98
so were is the best place to put it at?
u mean on the manifold like ur the pcv gos?or the ports on the t-body it self?
There are two (one coming off either side of the intake by the throttle body) and either of thoes ports will work fine. I use one for wastegates and the other for BOV.
