10 Second Club - Will this get me to tens??
View Full Version : Will this get me to tens??
CharlieSS
08-06-2006, 10:35 PM
I need to know if you guys think this will get me into the 10's
2000 Camaro SS M6
402 Slp Shortblock
LS6 Stock Heads
G5X3 Cam
Nology Wires
Ported Throttle Body
Mass Airflow Bypass
Dynatech Headers with Y-Pipe
Exhaust Dumpler
Underdrive Pulley
9 inch Ford Moser Rear End
31- axles
3:73 Gears
Spec- 3 Clutch and Fly-wheel
TNT- 150 wet shot
Tunned by a reputable shop.
What do you guys think? :bang:
TS6
08-07-2006, 09:56 AM
It could, depending on weight and your ability to drive.
Smartass6885
08-07-2006, 12:02 PM
go with 3.89's in the 9". its not a big diffrence. But it would work well since you are spraying. that should be plenty for 10's in a full weight car. take some weight out and go mid 10's.
CharlieSS
08-07-2006, 07:21 PM
I am wating a little. This is gonna be my daily driver. I am planning on porting the heads next year. Then I want to see low 10's on full weight.
mattrick
08-08-2006, 05:15 PM
Like they said. Get that tuned right with that stuff you should be asking will this get me high 9's? Good luck with it, nice setup
CharlieSS
08-08-2006, 10:35 PM
Hopefully. I want to wait for a rollcage before I do anymore upgrades.
1fastws6_02
08-08-2006, 10:45 PM
you should be able to run 10's easy with that setup and full weight.
my daily driver has run 10.33 with a 1.38 60 ft. at 3700lbs.
on a stock cube and stock bottom end motor on a 200 shot.
10.60 on a 150 shot.
cws T/A
08-10-2006, 05:41 PM
low tens , what cam ,heads, for how long ?
which kit ?
4yall2nv
08-12-2006, 01:32 AM
1fastws6, what are mods on your car, sounds good for dd.
02 Camaro SS
08-12-2006, 09:10 PM
I would expect high 10s in that setup without the spray. I don't think you should have any trouble.
nexvctm2001ss
08-22-2006, 03:29 PM
OK Im calling bullshit not being rude but you are :loco: and if it did you should have made a video and if you have a video post it until then Bullshit IMO sorry :judge:
