Headlights and front speakers do not work after M6 swap
OK WEIRD one I just did the M6 conversion, installed a new M6 wiring harness, and flashed it to an M6 program.
Everything works fairly well except the front speakers which I was using the factory amp for, and the headlights.
I have not hooked up the backup lights yet, I thought the headlight problem maybe the emergency brake switch but I grounded that out and gave it a 12v power source and neither got the headlights on. Checked the headlight fuse in the engine compartment and swapped it with an ABS fuse just in case. The running lights and fog lights work as do the brake lights.
Also the switch for the brights is F-dogged. The wipers still work, and turn signals but there is not switch front and back just a smooth loose movement. Must have screwed it up taking the steering column in and out ten times
Don't know where else to post this? Am I missing a ground somewhere? any ideas?
