Will 19x9.5 w/ 40mm offset fit on all fours?
I just bought a set, and im going to run 265/30R19 in front and 275/30R19 in back. i think the back will fit no problem, but will the front turn/ I saw the tire guide up top, and it says it should work??? anyone have this kind of setup?
40 mm offset will work just fine, although I question your tire choice . . .
If all four wheels are identical why wouldn't all four tires be identical???
A 265 is too narrow IMHO for a 9.5" wide wheel. The ire will llok narrower than the wheel
I'd run 275's on all four corners and call it a day.
I may end up doing just that, but I kinda wanted the front to look a little smaller, but well see. Im going to buy the tires after work, so ill make my decision then. Thanks for the info though.
Scott
Scott
