Guys with 500whp+ w/ T56 come on in
Old 08-07-2006, 01:01 AM
Blk97WS6's Avatar
Default Guys with 500whp+ w/ T56 come on in
Whats up everyone, have a few questions that my buddy asked for some info on. He has a 98 Z28 with 500whp, and currently has a blown T56. We were wondering what kind of manual trans set-up you guys would recommend for this much power. Any info at all would be greatly appreciated.
Old 08-07-2006, 02:16 AM
Sigforty's Avatar
If he does alot of racing and not much street driving he can proshift the T56. There are a few upgrades than can be made in a rebuild like hardened shafts, steel shift fork and the carbon material blocker rings.
Old 08-07-2006, 05:15 AM
bmfcamaro's Avatar
talk to ls1joe at t56rebuilds
Old 08-07-2006, 07:14 AM
TOSTO RACING's Avatar
I would stick with the t56. Mine is proshifted ,but everything else is stock and its working fine.
Old 08-07-2006, 12:14 PM
Blk97WS6's Avatar
he pretty much daily drives it, with an exception on a few nice days were he drives his bike, so do you guys think something like that would be tolerable in a DD?
Old 08-07-2006, 12:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
More than likely he blew the syncro's but we use a stock tranny with upgraded syncro's shift fork for our 800hp/800tq car without issues.
Old 08-07-2006, 12:34 PM
hyde's Avatar
Go with Joe at T56 rebuilds...He is the ****...Fast turn around too....I believe he is a sponsor here
Old 08-07-2006, 01:14 PM
Blk97WS6's Avatar
awesome thanks for the info guys..ill have him give Joe a call
Old 08-07-2006, 01:35 PM
Red97Z's Avatar
The T56 is a great racing transmission that can be built to withstand a great amount of power. I built mine up and it can now withstand over 500 rear wheel horsepower. There are multiple websites, sponsors and shops that can prep your friends transmission for him.
Old 08-07-2006, 02:44 PM
MIGHTYMOUSE's Avatar
i'm gonna take a shot in the dark and say that the trans is either jammed in a gear, or that it is grinding gears.
neither of the above are a result of abuse from high horsepower, rather abuse from the driver.
rebuild it with the stock upgraded components and practice safe shifting
Old 08-07-2006, 03:34 PM
Blk97WS6's Avatar
well we figured it wouldnt be to bad either once we got it apart. it would grind a bit into third, and would always pop out of 5th and reverse, so we figured only a couple syncros would have to be replaced, turns out all the syncros and gears were pretty much fried along with his clutch. he was having some problems with the trans ever since he bought the car when it was stock. then added a TR224, all bolt ons, 12-bolt and sticky tires, and the trans got worse. he then hit it with a 125 shot and a good tune. so the trans has had some abuse.
Old 08-08-2006, 01:02 AM
kenkaru's Avatar
What does "Proshifted" mean?
Judging from your sig pic, whatever it is, it must work!
Old 08-08-2006, 01:46 AM
Sigforty's Avatar
Proshifted is normally straight cut gears and they pull the over drives out as well. The car trans becomes a T56 four speed car, and the straight cut gears often eliminate the need to use a clutch for shifting as well.
Old 08-08-2006, 04:00 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Probably a simple rebuild would suffice for a 500+ setup. Some of the stuff that these guys mentioned above is a great start.
Old 08-08-2006, 12:15 PM
Blk97WS6's Avatar
i think is is going to go with package #3B from T56rebuilds.com
Seems like it would be good for that kind of power.
What do you guys think?
Old 08-08-2006, 01:20 PM
daryl2cb@yahoo.com's Avatar
new hardened shift forks, what ever else you can get out of a viper tranny and kevlar stuff is great too.
Quick Reply: Guys with 500whp+ w/ T56 come on in
