Sticky Please? Useful Part #'s & Torque Specs for FAST 90 Install
1 Post
I don't think this is anywhere in this forum, but I thought it would be useful to our fellow members. Anyone who does not already have the coolant lines under the original LS1 manifold relocated, here are the part #'s for the LS6 set-up ('02+), which works wonders when installing the FAST 90 Intake because of clearance issues. (If you install it and leave the original cooling lines there, you will not get a good seal; I just learned this from experience.) Also, 89 inch lbs. torqued = 7 ft. lbs. torqued. (Important because FAST does not convert this for you.) when you torque the intake bolts.
Part #12602544 Coolant Pipe (small and looks nothing shaped like original)
Part #12602540 Cover (you need this as well)
(Both at GM Dealers.)
Just thought I could help!!
