svo injectors?
Old 08-07-2006, 04:23 PM
KilerTA's Avatar
Question svo injectors?
I need some svo 30 llb injectors I know ford makes them but where can i get them ? whoi sells them? how much? and what color top do i need i think its green correct.
Old 08-07-2006, 05:22 PM
HSV-GTS-300's Avatar
30# = Red top
Google part number M9593B302 or for a "flow matched set" M9593B302F
About $290 new at the moment....one online store is showing $285 for matched 30#'s
Old 08-07-2006, 05:46 PM
SDPC http://www.sdpc2000.com/catalog/1708...jector-Kit.htm
Speed Inc http://www.ls1speed.com/cart.cfm?act...item=INJ30%2D8
New Era http://www.neweraperformanceparts.co...1154989990484&
WS6 Store http://www.ws6project.com/user_stor/...5a2082d5bc087a
Old 08-08-2006, 07:58 AM
sprayjunkie's Avatar
FWIW motorsport 42#s sell for about $250-275, check the ford sites.Look up Diversified products marketing....
Old 08-08-2006, 10:10 AM
jinxedz's Avatar
Awesome post.
Old 04-23-2007, 07:10 PM
Phil'sC5vette's Avatar
Its crazy the swing and mark up in price
Looks like WS6 store has the best price. That's $125.00 dollars less then several sponsors.
Thank god for google
Old 04-23-2007, 07:25 PM
brad8266's Avatar
F 32's, go larger and get the 42's. They allow plenty of room to grow.
Old 04-23-2007, 11:38 PM
CaliboyTA's Avatar
http://cgi.ebay.com/ebaymotors/30-lb...QQcmdZViewItem
Got my injectors from him, no problems what so ever, good guy to deal with
Old 04-24-2007, 04:12 PM
cam
cam's Avatar
This is what I want to do but my tuner advised against it claiming they act much bigger due to the LS1 fuel pressure. Said the 30's would work well without a tune and easier to dial in. Around 400 rwhp what do you think of this advice?
Old 04-24-2007, 04:29 PM
brad8266's Avatar
The 42 SVO's are fine on a 400Hp car they wont cause any minimum pulsewidth issues which is what becomes an issue when you use too large of an injector.
Old 04-24-2007, 04:31 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I'm not seeing it. Here's a quick comparison for you.
Item...Them...Us
19#...$255...$215
24#...$325...$294
30#...$295...$294
42#...$455...$389
150#...????.....$398
Just an FYI...We keep them in stock too
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-24-2007, 06:27 PM
Matt,
SDPC price is nice, but Ive seen them as high as almost $400.00 from others
Old 04-24-2007, 06:36 PM
gillbot's Avatar
What about harris speed works?
I also say go for the 42's.
Old 04-26-2007, 01:30 PM
best price:
FUEL INJECTOR SET 30 LB/HR 86/95 MUSTANG (FRPP)
Ford Racing Fuel Injectors, 30 lbs/hr (red), for 1986-and-later Mustang with modified EFI 5.0L/4.6L V8 engine.
Increase your fuel flow rate by adding performance injectors. This kit includes 8 red fuel injectors rated at 30 lbs/hr. When using these injectors you will need to recalibrate the mass air meter.
Recommended for engines with increased breathing capability and fuel pressure.
Price: $259.95
In Stock Now!
Email product information to a friend.
Old 04-26-2007, 02:48 PM
Nice, below cost! I should buy all they have
__________________
Old 04-26-2007, 03:11 PM
Ford Racing 30lb Fuel Injector Set
Kit contains 8 high-flow rate 30lb. fuel injectors, specially designed for race applications. These injectors work best with air meters with revised calibrations. Not recommended for stock air meters.
Your Price: $239.00
Plymouth MI
48170 USA
Old 04-26-2007, 03:40 PM
YellowToy/A's Avatar
Cam At 400 HP I dont think u need new ones. Keep what you have as long as the air/fuel ratio is below 13 and what your highes RPM and full throttle. If you need more get the 42 lb/hr green top.
Old 04-26-2007, 03:45 PM
1fast01's Avatar
Ford Racing 30# injectors are actually 36#'ers with LS1 fuel pressure, just FYI
Old 04-26-2007, 04:51 PM
Ive hit up to 120 % of my injectors duty cycle at WOT with my set up.
Im still using the 28.8. that's why im on the market for 30 pounders
Old 04-26-2007, 06:49 PM
Moderator
davered00ss's Avatar
I found an add in Muscle Mustangs and Fast fords (don't ask why I have it) For $209 this month. For ford SVO #30 red top injectors set of 8.
Quick Reply: svo injectors?
