Missing a FAST 90mm Gasket!
I have a FAST 90 Intake Manifold and FAST 90 Throttle Body but I have no gasket to connect the two together. The new engine is assembled and awaiting a tune but I ened to solve the gasket issue asap.
Does anyone here know what I can use as a gasket in the short term, at least something that will last reliably through a day of tuning while I figure out a better long term solution? Don't wanna use paper or cork or RTV or anything like that, and the stock gasket obvioulsy won't work, since the surfaces of the TB and manifold are flat, not grooved.
That's what she said...
Did you buy the manifold new? If so, it comes in the box. It's doubled over, so it looks like a smaller one. BYUNSpeed sells them if you can wait a bit. Try to find a gasket place in your area and see if they can help you out. We have tons of places here that will make any kind of gaskets you can imagine.
