Free Ram Air...
Old 08-09-2006, 11:19 PM
irnbru83's Avatar
Default Free Ram Air...
Soooo, this question has probably been asked a few times, but i'm newb, so i get to ask again.
Is this seemingly easy fix for more air really as easy and straightforward as it sounds?
http://www.fbody.com/tech/details.cgi?id=54
I don't know enough to know if there could be consequences for this. I kinda buy the whole "they restricted the f-bodies so that they would not outperform the corvette", but i duno.
Old 08-09-2006, 11:23 PM
Tainted's Avatar
the filter will get dirtier quicker, also it may cause the air temp to warm up, but you need that free mod to do the CAI kits
but its very easy to do. I did mine with an air saw but then again im at a body shop so I can have that done in 2 mins flat
Old 08-09-2006, 11:32 PM
RrCoX22's Avatar
do it and never look back
Old 08-09-2006, 11:36 PM
irnbru83's Avatar
like 1000 miles quick, or 15,000 miles quick? :o
and i wouldn't do this by myself most likely, one of the mechanical dudes at work wants to help me out.
EDIT: i'm an EE, so i don't trust myself with my car unless i'm rewiring the stereo.
Old 08-09-2006, 11:37 PM
BayAreaSS's Avatar
Its very easy to do. Your filter will get dirty but thats no big deal. DO IT
Old 08-09-2006, 11:40 PM
taintedmeat's Avatar
I actually reversed mine and it seems to run better. It's hot as hell here all summer though, not sure what this "heat wave" is the whole country is crying about
Old 08-10-2006, 12:14 AM
RrCoX22's Avatar
if you cant do this i honestly don't think you deserve to own such a car
Old 08-10-2006, 05:58 AM
irnbru83's Avatar
yeah well, if it's just cutting away a couple pieces of plastic, that should be easy :p
I just moved to Houston from Austin Tainted... it's a lot more humid here, not so cool
Old 08-10-2006, 10:18 AM
irnbru83's Avatar
Easy stuff. Oh well, always better to ask first than to go ahead and screw something up.
Old 08-10-2006, 10:42 AM
nvrlast's Avatar
You should deffinatley do it. I didnt do the free mod but I bought the whisper kit and picked up .2 of a second and 2MPH with the mod. My filter tends to get dirty 2000-3000 miles, its not a big deal I just clean It when I change my oil. Good luck!
Old 08-10-2006, 12:38 PM
LILWS6's Avatar
for slp's flow pak intake you have to do this anyway or it wouldn't work
Old 08-10-2006, 12:50 PM
ZL1Killa's Avatar
do it and make a seal so that you don't take hot *** air from the radiator
Old 08-10-2006, 01:25 PM
That's what she said...
TheBlurLS1's Avatar
Easy as pie. Look up SSRA or FTRA and throw one of those in.
BTW - The LS1 f-bodies are not "restricted", they are just under-rated. The same LS1 is in all of them. The stock f-bodies have even been known to dyno higher due to the solid axle vs. the IRS sported by the 'vette.
Old 08-10-2006, 01:38 PM
irnbru83's Avatar
yeah i saw an article yesterday about the '98 t/a dynoed against a '98 vette and the trans am was up by 12 hp at the wheels.
