qtp ypipe and driveshaft loop?
Old 08-10-2006, 02:50 AM
vader99's Avatar
Default qtp ypipe and driveshaft loop?
Which driveshaft loop will clear the qtp ypipe with the flomaster merge collector?
Old 08-10-2006, 08:22 AM
86 IROC's Avatar
Lakewood, or you can get a reboxed Lakewood from Spohn that has been powdercoated - same design.
Old 08-10-2006, 08:33 AM
JoeyAnderson's Avatar
That loop should fit with any exhaust. I'm using it with my TSP True Duals.
Old 08-10-2006, 07:05 PM
ls2 bait's Avatar
well the bmr doesnt. i just spend 4 hrs cutting and welding mine to make it fit. i would have bought a lakewood but i needed it for tech this weekend.
Old 08-10-2006, 07:42 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Lakewood here..should clear anything..it is pretty adjustable unlike some others I have looked at...Edelbrock 3 -1/8" Y-Pipe. Says 3" but have measured it..
Old 08-10-2006, 10:46 PM
vader99's Avatar
So, the Lakewood will actually clear the huge 4" - 3" section which connects to the ipipe?
Anyone actually use the lakewood with the qtp ypipe to be sure?
thanks...
Old 08-10-2006, 10:50 PM
NHRAMAN's Avatar
Exclamation
thanks...
It clears my y with room to spare.
Old 08-11-2006, 11:38 AM
86 IROC's Avatar
thanks...
I had a QTP OR Y-pipe on my car prior to the TSP duals and it worked fine.
