98 mac headers
Old 08-10-2006, 01:19 PM
BurtReynolds's Avatar
Default 98 mac headers
Do 98 midtube headers fit on a 2000 trans am.What would I need?
Old 08-10-2006, 01:35 PM
That's what she said...
TheBlurLS1's Avatar
Yes they would fit, but you might have a hard time getting the AIR/EGR to line up. If you delete that crap, you wouldn't have to worry about it. Check the AIR/EGR sticky for more info on that.
Old 08-10-2006, 01:51 PM
jmm98LS1's Avatar
I gave my 98 macs to a buddy with an 00 TA and they fit fine. Like Blur said, the emissions fittings are the only thing that's different. You can either delete the emissions and cap the fittings on the headers, or modify the 2000 fittings to hook up to the 98 fitings. My buddy wanted to keep his emissions stuff, so all that was needed was to make the driver's side AIR hose longer (we used heater hose) and the EGR tube needs to be cut shorter and bent a little. The tube is easy to bend, it's made of "flex" pipe with the ribs that keep it from kinking. If you have any problems just let me know and I'll help ya out.
Old 08-10-2006, 02:01 PM
8GTOKLR's Avatar
you need air tubes from the 98 also cause they are *** backwards. I got them from GM for 90 bucks and then its plug and play from there
