Finished my front suspension set up
9 Sec. Club!!!
Finially finished my front suspension.. I installed a D&D K-member, A-arms, Coil overs with 250lb springs, Maximum Motor sports 4 bolt Caster/Camber plates, KYB AGX adjustable struts, and sway bar.. I had a few issues with the D&D K-member rubbing on the steering shaft but that is going to be taken care of, also my passenger side header is touching the K-member.. I think I hammer can take care of that or the plasma cutter I will see which once I want to mess up.. So far it feels great, the supsension is a hell of alot tighter and can take some awesome corners.. I feel like I have better control of the car now on the road.. Handling is 100% better. I also lowered the front end about 1/2-3/4 of an inch.. It looks good now but I think maybe another 1/4 inch would look a little better.. At least now it doesn't look like the rear is lower then the front. Now I just need to get everything alligned..
9 Sec. Club!!!
Originally Posted by SSilverSSurfer
still gonna pull the wheels?
Originally Posted by dan03mach
Thanks alot man, I'm going to enter in all 3 of the index classes to try to win 600 bucks 200 per class.. If I win one that would be great.
9 Sec. Club!!!
Originally Posted by V6 Bird
2" Wheelies are the ****. I used to do that on my Huffy.
