Southern Members - North GA rear end shop
View Full Version : North GA rear end shop
kick_*ss
08-11-2006, 08:14 AM
Anyone out there recommend a good shop out there that can replace the ring/pinion/carrier and crush bearing?
I
After all the fun from when I had the clutch put in, and THANK GOD thats working, but when he tore apart the diff to put in the motive gears ( which did not match up to the series 2 carrier ) he did not replace the crush bearings and they its leaking now out the front of the diff :( SOOO, since its obvious I have to get that fixed I am going to get the series 3, and put in the gears I wanted in the first place.
But I sure as hell wont use the same place.
Anywhere north of Atlanta would be great.
thx
Out1aw
08-11-2006, 08:38 AM
PM SS Rally Red. His shop is located in Loganville, GA.
ss rally red
08-11-2006, 07:28 PM
Jeez how can you install a new set of gears and not use a new crush sleeve???? Did he replace the pinion gear and reuse the old crush sleeve??? if so RUN LIKE HELL,LOL if I can help give me a call 770-978-8502 the name is Ken. Also if its leaking out of the front of the differential it is the pinion seal that is leaking,all of that should have been replaced upon the install.......
