Ls1 Carb/distributor
i have a 98 ls1 engine that i have been wanting to put into an older vehicle, i will be going with a carb conversion. i see that gmpp has come out with a new front timing cover that allows the use of a distributor and a mechanical fuel pump. i am wondering if anybody has used this setup, and is there a waterpump out there that will clearance this new cover? also what distributor and fuel pump will work with this? i can't seem to find much info on this setup. any help is appreciated. i have thought about using the msd timing module, but i like the idea of being able to tune my engine the old fashion way. thanks
thanks for the info, i did read the article in hi performance chevy, about this setup, but still not much info on parts availability. my main concern is that darn waterpump, there is just no way the stock one will clear. i work at a chevy dealership, and i can get the parts at cost, but there is no listing yet. hopefully soon though!
Here's some reading for you:
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html <<results
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html <<dyno results
https://ls1tech.com/forums/generation-iii-external-engine/314549-carbed-intake-converted-f-i.html
https://ls1tech.com/forums/generation-iii-external-engine/320023-gmpp-carb-efi-conversion.html
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/generation-iii-external-engine/414468-gmpp-intake-vs-edelbrok-victor-jr-ls1.html
https://ls1tech.com/forums/drag-racing-tech/425512-search-down-what-edelbrock-victor-jr-worth-over-fast-90-90-a.html
https://ls1tech.com/forums/generation-iii-external-engine/449835-any-ls1-carb-engines-out-there.html
https://ls1tech.com/forums/generation-iii-external-engine/460478-my-vic-jr-conversion-pics-thoughts.html
https://ls1tech.com/forums/generation-iii-external-engine/463438-msd-wire.html
http://www.edelbrock.com/automotive_...ds_chevy.shtml
I'm in the same boat as you, VERY limited info on this set up. I did however see several cars using it on the Power Tour this year. Mostly on cars at the Year One booth, I'm considering giving them a call to see if they can point me in the right direction. I was told the distributor they use is sourced from a ford 351W.
and from what I remember them saying the dizzy is from a ford 302
also, even more so on a new motor, the box has to see 150 cranking rpm or the box will not fire.
i had 2 batteries on my 408 to get it fired over the 1st couple times. after a heat cycle, it fires up on the 1st hit.
buddies 6.0 rebuild did the same thing. voltage is very important.
it wont work as a standalone. it only sends spark. no fuel.
youll need the stock pcm for fueling, or some other type of aftermarket setup.
for 300 bucks, it does a good job, IMO.
something to do with the coil drivers. i dont think anyone or even msd knows how many is in the box. LOL. with high rpm, it breaks up.
I've seen that episode this morning, too. Can't remember what carb and intake it was, but they used a double roller timing chain, meziere electric water pump, and some spacers for the water pump so that it would clear the cover. And the distributor was a msd for a ford 302. Pretty interesting set up I think, made real good power on their dyno, too much work to do IMO, I would just keep it with the coils. I also remember them saying that the fuel pump was too much for the carb and would cause overflow or something, but great set up anyway.
carb, carburated, carburator, carbureted, cnversion, conversion, cover, distributor, dyno, edelbrock, engine, intake, ls, ls1, results, timing
