L.E.D. clear corner question
Old 08-12-2006, 04:36 AM
blue-ss-camaro's Avatar
Default L.E.D. clear corner question
I want to swap my stock bulbs for L.E.D.s in my corners for the turn signal. what do i need to do? what bulbs, flasher, etc......
Old 08-12-2006, 07:39 AM
redsscamaro's Avatar
They sell the 194 bulb already with l.e.ds at a-z0ne, they light up amber
Old 08-12-2006, 08:59 AM
Transamin00's Avatar
the one you will find at pep boys and auto zone are pretty crappy. use these
http://stores.ebay.com/Velocity-LEDs...QQftidZ2QQtZkm
and here is the flasher you will need
http://cgi.ebay.com/ebaymotors/led-t...5920QQtcZphoto
Old 08-12-2006, 12:29 PM
NightWindDriftr's Avatar
Can anyone vouch for the brightness of LEDs vs the stock bulbs? I've been hearing a lot of "it's not bright enough to be seen in daylight", which is a huge hazard.
Old 08-12-2006, 12:40 PM
Z28-CTYHNTR's Avatar
Yeah, I would love to switch to LEDs because the bulbs i use always melt the clear corner housings. But the primary reason I havent switched to LEDs yet is because Ive always heard they arent bright enough.
Old 08-13-2006, 06:32 AM
anyone esle have some light on this subject....
Old 08-13-2006, 08:36 AM
mcgodx's Avatar
My buddy has LEDs, and I haven't seen his car since he did his fronts, but I did see the back, and they are very dim. I was able to see them, but they didn't light up that bright at all. I wouldn't like them.
Old 08-13-2006, 04:37 PM
_JB_'s Avatar
I have leds in my side markers, mirror and dome lights, and the lisence plate light. I got the interior leds from http://www.ledgauges.com and the others at www.superbrightleds.com. For all the exterior leds, I used WLED-x5 LED Wedge Base Bulbs from http://www.superbrightleds.com/mini-wedge.html
They are very close to the same brightness as the stock lights, but I'm still using the stock corners, not sure how it would look with clear ones.
Old 08-13-2006, 09:54 PM
DirtyBird222's Avatar
high intensity discharge LEDs are on their way in, so I'm sure when they are available to the masses they'll be bright enough for daytime use!
Old 08-13-2006, 09:55 PM
man the white WLED-x5 bulbs come off more light blue than they do white, pisses me off! I've never had a problem with superbrightleds either!
Old 08-14-2006, 08:13 AM
_JB_'s Avatar
I thought the same thing with both the wled-x5 and the wled-x6 led ones.
Quick Reply: L.E.D. clear corner question
