i have a small problem...
Old 08-12-2006, 12:14 PM
s346k's Avatar
Default i have a small problem...help needed.
there is now an 1/8" crack on the back of my transmission, 1/2" in front of the transmission mount. it spans the width of the tranny from top to bottom on the driver's side. i have a prothane poly trans mount.
i was in overdrive @ appx. 140 mph when this happened. the car was pulling smooth and i had no noises prior to the incident. i heard / felt a thud, which was immediately followed by billowing smoke and a whirring noise.
wtf caused this?
Old 08-12-2006, 12:26 PM
Predator T/A's Avatar
well something came apart and sounds like it craked the case and those mounts can brake trannys they dont let it give enugh and cause too much vibration in the tranny
Old 08-12-2006, 01:59 PM
s346k's Avatar
ttt.....
Old 08-12-2006, 04:39 PM
FLT
FLT's Avatar
Do you have the torque arm bolted to the tail housing? We see alot of these housing's broken on f-body cars. Relocating the torque arm mount might help. Have you lowered your car or felt any vibrations? You probably should have your driveshaft length checked and balanced.
Old 08-12-2006, 08:07 PM
s346k's Avatar
it is the factory torque arm and has not been off the car. i would consider a chassis mount torque arm, but my exhaust prevents that route.
the car is not lowered (stock z28 springs/shocks) and the only vibration i noticed came immediately after installing the prothane trans. mount.
i had plans of switching to an al driveshaft from another ls1 car this week, anyway.
do you think anything else is damaged, or just the housing? i am going to take everything apart tomorrow and hope for the best. i am afraid that much more is damaged than just the housing itself.
Old 08-12-2006, 08:28 PM
FLT
FLT's Avatar
With any luck a housing will fix it. At 140mph it's a crap shoot! I guess you'll have to see what happens. I would think about re-doing your exhaust to relocate your torque arm. If the trans needs to done feel free to give us a call. Good luck, Vince.
Old 08-13-2006, 01:23 AM
2xLS1's Avatar
Steel driveshaft I bet. Change it to the aluminum one. Steel driveshafts will even crack them after relocating the tq arm.
Old 08-13-2006, 07:19 AM
King James's Avatar
Sean I have tons of 4L60E parts laying around the shop. Get me pics of exactly what broke and I'll see if I have it. If need be, my trans is still laying on the ground so you could borrow mine till you get a new one.
Also you might want to look into the BMR or UMI torque arm relocation kits.
Old 08-13-2006, 11:55 AM
s346k's Avatar
thanks for the replies guys. i will post pics after i get some, i am in the process of disassembly now.
thanks for the offer james, i appreciate it. nathan has a 4l60e sitting on his garage floor that i will take the housing from. if the housing is the only problem, i will replace it with his just so i can run this weekend, then buy a new one and replace whatever else i think needs it, as well.
also, i've already given the exhaust a lot of thought. i will change the housing, swap to an al driveshaft, and replace my prothane mount with a stock one. if i have this problem again, everything from the converter back is getting replaced, and a chassis mount tq arm is going on. i have very little patience with things like this.
Old 08-13-2006, 12:51 PM
Yank's Avatar
one of our crossmembers will cure the torque arm load issue and clear the exhaust
http://www.converter.cc/drivetrain.htm
the 3.73 gear and Propshaft RPM at 140 in OD are the cause with the stiff poly mount
Old 08-13-2006, 02:16 PM
s346k's Avatar
so it was worse than i thought, it was completely separated from the trasmission 360* around. thankfully the output shaft looks good and no other damage occured. i am leaving to get another housing right now. hopefully it will be up and running soon.
Old 08-13-2006, 02:18 PM
blkbird_WS-6's Avatar
Dayum!!!
Old 08-13-2006, 02:32 PM
BlackHawk T/A's Avatar
Now that's some tranny ownage.
Old 08-14-2006, 08:10 PM
King James's Avatar
That's impressive!
Old 08-14-2006, 09:50 PM
s346k's Avatar
the housing was the only damage. i replaced it with another, swapped from a steel driveshaft to AL, installed new u joint and tailshaft seal. it's fine again. w00t!
moral of this story: poly trans mount > stock rubber motor mounts
Old 08-14-2006, 09:55 PM
SSmoky01's Avatar
Pure!!! Looks like you where havin fun!!!
Old 08-14-2006, 10:07 PM
s346k's Avatar
hell yeah! i have a stack of timeslips literally 2" thick. been through a couple sets of tires so far this year.
Old 08-15-2006, 06:07 PM
Roarin_8's Avatar
I had the same thing happen to mines but not THAT severe. 6 inch hairline crack on the bottom. The stock bushing was shot (2 pieces), the shop replaced it with a poly bushing.
Old 08-23-2006, 01:48 PM
john shea's Avatar
Awesome photos of damage. Where were you when driving 140 MPH?
Quick Reply: i have a small problem...
