4l60e: How to replace the transmission pump?
Old 08-13-2006, 10:51 AM
jimmyp's Avatar
Default 4l60e: How to replace the transmission pump?
What is involved with changing the pump on a 98 f-body 4l60e?
Old 08-13-2006, 09:35 PM
1999Z28's Avatar
removing the tranny from car. removing pan and then 1 or 2 of the shift solenoids(i think thats what they are). remove bellhousing (T55+ torx bit) and then the bolts on the pump and you can pry it up and out. There is a special kent moore tool to do it, but pry up gently works fine.
Old 08-14-2006, 12:29 AM
69rat's Avatar
be sure to be careful removing the o-ring on the input shaft before you pull the pump housing out. if it gets damaged i've heard it can cause the trans to set slipping codes.
Quick Reply: 4l60e: How to replace the transmission pump?
