Is a breather required on drivers side valve cover
Old 08-13-2006, 06:14 PM
bowtieman81's Avatar
Default Is a breather required on drivers side valve cover
I just want to know if I need to have a breather on the my drivers side vavle cover? Right now it has a plug in it from being n/a. I plan to have the pass side valve cover and LS6 valley cover used in my PCV setup.
Old 08-13-2006, 06:20 PM
frcefed98's Avatar
I have one, ran a hose from the outlet on the VC to behind the brake booster and plug a breather into that. Kept it clean and the oil vapors off the header/manifold.
Old 08-13-2006, 06:23 PM
Thanks, good idea.
My main question is will I have any negative effects if the drivers side vc has no vent at all?
Old 08-13-2006, 08:10 PM
JMBLOWNWS6's Avatar
I just jumper them across the back and use the metco breather on the passanger side.
Quick Reply: Is a breather required on drivers side valve cover
