Stall ET times?
Old 08-13-2006, 07:15 PM
MonsterZ28's Avatar
Default Stall ET times?
What are you guys runnin at the track with just a stall? and bolt ons.... no head and cams!!!
Old 08-13-2006, 09:27 PM
s346k's Avatar
see sig
Old 08-13-2006, 09:31 PM
1999Z28's Avatar
with headers, 4.10s, a tune and other simple basic stuff im running 12.30 @ 113 with a 1.85 60ft on BF goodrich drag radials.
with the 3500 tci converter i havn't gotten to run in nice weather. so it's only gone 12.30 @ 110 with a spinning 1.76 60ft, so im pretty sure in good weather and hopefully my new mickey thompsons it'll hook up good and hit 11s
Old 08-13-2006, 09:37 PM
SouthernSilverSpeed's Avatar
only 1/8 mile times
1.76 60ft.
8.10 1/8 mile
mods listed below
Old 08-13-2006, 09:52 PM
kruthes1's Avatar
only 1/8th here too.
Old 08-13-2006, 10:57 PM
SVT THIS's Avatar
Wow those 12.3s make me want to go to the track with my 4400!
Old 08-16-2006, 02:30 PM
seadoo's Avatar
I got a buddy of mine's 00 T/A down to a 12.2 @ 108 with a 1.59 60'. 110% stock suspension, front swaybar on, stock 16's up front and 275/50 MT DR's out back. and that was in 80* weather
mods where...
pacesetter headers
custom 3" ORY
Magnaflow catback
lid
4000 fuddle stall
tuned my me using HP Tuners
dont even have a ls6 intake, pulley, or ported tb
now we just installed UMI adjustable torque arm, boxed LCA's and a Sphon PHR and matching 15X3.5's up front and took off the swaybar.
I suspect that in -DA and good weather we can get a mid 1.5 and a high 11 from her!
Old 08-16-2006, 07:41 PM
2002LS1Z's Avatar
See sig, I need some DRs.
Old 08-17-2006, 01:36 AM
ultraz's Avatar
search, thers a big thread on this already.... went from 13.2 with Lt's and SUPER basic bolt ons to 12.6 with 3600 stall and some DR's. Great thign is that theres much more in it because I didnt warm up the DR's like i should have. only pulled 2.0 60's
Old 08-17-2006, 01:46 AM
camscam02's Avatar
see sig!
Old 08-18-2006, 03:23 PM
chrs1313's Avatar
11.72 at 115.4 with a little 3600 and complete stock exhaust with cutout, check out sig
Old 08-18-2006, 03:39 PM
'Trust''s Avatar
Do you have a alternater pulley with that 25% one?
Old 08-18-2006, 05:09 PM
BlackHawk T/A's Avatar
Not sure but that DA of -950 sure is helping.
Old 08-18-2006, 06:24 PM
radz282003's Avatar
I' ve only gone 12.6 @ 108 with a 1.7 60', on DRs. That was on a run where I left the line at a little more than 1/2 throttle, and the car shifted into second before I was WOT. My bad.
With a similar setup, but OEM TA, a SS4000, and 3.73s, my brother just went 12.2 @ 110 with a 1.6X 60'. I think there is another 10th or so in it.
We are full weight cars.
Old 08-18-2006, 09:07 PM
I have the same problem...when I lay into it to keep traction, it will act like normal and go up into 2nd...then when you get your foot to the floor, it sees that and then goes BACK down into 1st again...gotta be something you can fix with tuning.
Old 08-18-2006, 10:39 PM
sixvi6-camaro's Avatar
best of 12.68@105 1.7 60 usually get 12.7's though thats full weight with a speed inc basic tune and on MT radials and the mods in the sig. I was actually shocked it ran 12's.. car ran 13.4 before the stall, trans, and tune.
Old 08-19-2006, 12:15 AM
ultraz's Avatar
he had slicks which hooked like no other, check his sig. his 1.6 60' is outstanding
Old 08-22-2006, 03:42 PM
chrs1313's Avatar
yeah it hooked good 26 tall by 10.0 in, and no stock alternator pulley just the underdrive crank...and yes the da helps, probably a solid 11.90's car in 1000 foot, i still could get gears, water pump, could have had a higher stall like 4200, and still need to get headers and either y or duals, and still need to get a full dyno tune...alot still left on the table so yeah da helps but i bet if i had headers and a 4000 plus stall that would help too...that is the reason i listed the da but everyone thinks it is all due to it...haha...its not
