99 stock injectors
99 stock injectors
i was just wondering if i could go with a bigget injector with a stock engine? ic i have smaller injectorsthen other years 26#, should i change them with 28#? woudl i notice any difference. thanks
as of right now, you will not notice a bit of difference. injectors typically need to be changed out once you see that your injector duty cycle is near or above 85% on your stock injectors. That can be read by using a scan tool such as EFI LIVE or HPTuners at Wide open throttle (WOT).
if you plan on doing heads, cam, your kooks lt headers, true duals, TB, intake manifold....etc; then i would say you would need some new injectors.
its not that you will notice a difference its that you will need the extra fuel for all of that extra air that you will be getting at WOT
